Display Driver Uninstaller 12.9.7.0
Dicehunter
Resident Newb
New DDU has been released, Fixes a few bugs and issues -
Changelog:
  • DDU is now removing (some of the ) "Audio Endpoint" for nVidia and Intel.
  • Disabled the removal of the "AMD HD audio bus" as it is still not perfect
  • Environment path CleanUP adjustments.
  • Additional nVidia shortcut/folder CleanUP
  • Language update : Japanese and Korean.
Shame it fried the LAN driver for my motherboard last time I used it.
Fried it :confused:
Sorry to say bud but you must have something very wrong with your system if a driver removal program fried your lan port :(
*Edit* Ignore that last one, Misread your post ^_^
At any rate it shouldn't touch your LAN driver, I run this monthly *or when there's a driver update* on 6 different machines running a mix of Intel, AMD and Nvidia, Not 1 has had it's LAN driver buggered up.
Fried it :confused:
Well it was fine until the last time I had to do it to get 14.4 on my AMD rig. After I had done the normal proceedure I started getting bluescreens relating to a certain driver (this was before my memory broke). Reverted by to a previous point in time and it was fine. I did the exact same thing as I had done and it caused the issues again. I'm sure it was a fluke/bad luck but still, really was quite frustrating and basically stopped me from doing some good ol' benching for a while.
I also have a complaint about 14.4 but that is for another time...
My philosophy is this, It's man made so it's not perfect so when it can break it will break ^_^
