Dimensions
BOA279
Can some one please hook me up with the dimensions of the mach II GT case? I'm waiting for mine to arrive but I need the dimensions to finish my custom case. Please help! THANKS!
I'm not sure of the dimensions but I do know that it varies depending on whether you use the standard enlight panels (i.e. just the dimensions of the chassis) or if you have the lian li panels and it's slightly wider because of the mounting rails. I seem to remember it was 24cm wide with the lian li panels on if that helps.
