Digi Thermometers
Highland3r
DICE is sorted, need to get a "decent" digi thermometer sorted now... Can't afford a Fluke no matter how much I want one, so need something a little cheaper.
Gray reccomends DIGITAL THERMOMETER K102 (voltcraft) from http://www1.uk.conrad.com only issue is that it doesnt come with a thermocouple.
The only type K's i can find there or elsewhere seem to "max" at -100. Ok for DICE but not so good for LN2. Any pointers?
Second one is This
from mappers. Again dual input and comes with thermocouples this time...
Thoughts chaps?
Will any type K probe work to the limits of the device, or do the ranges actually vary
Cheers
I use thermocouples rated to -75c and they read down to -200c,although i can't measure accuracy.If you have found some to -100c,they should easily be good enough for ln2,as quite often,you will find yourself running in the -90c to -120c range.
Cheers - yea that site is a bit funny with links it seems...
Sorry to be a nubbin, can you point me in the right direction as to what type of sensor i actually need?
