Hi Everyone,
I have been messing with my machine best part of today, I recently had a leak which made my Asus P5Q-VM die so had to buy a new mobo. I bought a DFI Lanparty JR P45-T2RS off eBay from a guy which is in perfect working condition according to the ad and from inspection. He also had 100% feedback so I am confident the board is fine. However I have put it in and wired everything back up and no matter what I do the computer starts and then restarts four times for around 10 seconds a time and then stays on constantly. If I have no RAM or CPU installed it starts, stays on and does not reboot 4 times. Nothing is displayed through the graphics card and the fan on the card does spin up but as I said nothing is displayed.
When my leak occurred is it likely that the CPU is dead? Or that the graphics card is dead? or RAM or a combination? Only the area around the CPU was wet as it leaked from the CPU block and the leak wasn't too bad. As I said I have tried without RAM and CPU and it does not reboot it just runs but still nothing displays. Is it worth buying a new graphics card?? I was planning on replacing the ancient 3850HD sooner or later but being as I don't game I only use the computer for CAD and light render work it is only lightly used.
My spec is in my sig. Any help is appreciated!
Thanks
Joe
Thanks
Joe
