Destiny and Legacy 2016
Mageta Lion
So I'm going to rebuild / upgrade my 2 gaming rigs. For this build I use as cases
2 Parvum systems M1 cases that have been custom made for me. Here are the rest of the specs for each rig :
Destiny :
Asus X99 Deluxe
Intel core i7 5930K
32 GB Dominator platinum 2666mhz
2x EVGA GTX 1080 founders edition SLI
2x Samsung 750 evo 500 GB in raid 0
Parvum M1 case
Corsair AX1200 + ICEMODZ cables
fully watercooled by EKWB , Bitspower
Legacy:
MSI x99A SLI plus
Intel core i7 5820k
32 GB Hyper X fury 2400Mhz
2x EVGA GTX 980 super clocked SLI
2x Samsung 850 pro 256 in raid 0
Parvum m1 case
Corsair AX860 + ICEMODZ cables
fully watercooled by EKWB , bitspower
Here are some pictures from the unpacking I have done so far
custom frontpanels for the M1 cases , just love how they came together.
I know its same as Nvidia used for the "battlebox" cases, but I love the
design and I'm huge fan of Nvidia so I went for it
Custom PSU cables by icemodz , really like them !
Just finished building 1 of the custom Parvum M1 cases. My god... really like how this came together.
New CPU block from EKWB installed, and 32 GB of Dominator Platinum
motherboard is in now together with the radiators and PSU, now working
on the two GPU's
Good thing about having 2 gaming rigs is that you can rebuild one, and use the other for things like GPU testing. Making sure my new GTX 1080's are in good shape before I remove the cooler and apply the waterblocks.
Finished replacing the stock coolers from the founders edition to the new EKWB water blocks and backplates :)
working on the hard tubes and the pump area now, things are really starting to come together :)
almost done with the hard tubing, just 1 more to go, and then perfect everything see if all are as straight as possible and right lengths, so far I am happy :D
With the loop done I know where the pump will go, so I removed it and gonna drill some holes to put it in place later. Also added a cable tray for the pump wires
