dell poweredge 1400
nathan
i have a dell poweredge 1400 server in my attic, it is only running on 1 800mhz cpu at the moment, thinking of putting 2 1ghz cpu's in it, but i have 2 questions.
1. i need to buy another vrm module as it only has one in. anyone know a place i could buy these?
2. will i need special cpu's if there gonna run side by side?
thankful of any help :)
You should be able to get the VRM's from Dell. Luckily my Intel server had all 4 VRM's when I picked it up, just had to load in my 4 procs and I was ready to burn rubber :p
And you won't need special CPU's, all of the P3 Xeon's (i'm assuming that's what it uses) are all setup for multi-cpu systems. You can find matching pairs of new and used P3 Xeons on Ebay for cheap. I picked up my 4 x 500mhz 1mb L2 procs for like $35 for all of em :D
thanks for that frag, your always quick at replying, i will get in touch with dell and have a search on ebay.
ta
nath
ta
nath
I try ;) hehe
If you can't get them from Dell (which you should be able to), have a search on ebay for an old used server of the same type and use it as a parts machine.
