decent w cooler
You can make a Custom Setup which would be much better for A bit More Money.
What do you want to cool?
How much do you want to spend?
What Case do you have?
3 x Yate Loon 120mm D12SL-12 - 1350 RPM
1 x -Masterkleer 7/16" ID - 5/8" OD PVC Hose
1 x EK-Supreme LT i7 - Acetal (775 & 1366)
1 x 10ml PT Nuke Concentrated Biocide
1 x Arctic Cooling MX-2 Thermal Compound 4g
1 x ThermoChill PA120.3 - 360 Radiator (15mm)
1 x 12V Laing DDC-1T Pro 10W (MCP350)
1 x Laing DDC Top/w Reservoir (XSPC)
£196.52 From Watercooling UK, you just need hose clips which i forgot, as well as distilled water to add to the PT Nuke. And that is a top of the range setup :)
