Decent IPS monitor around £120
dacons
As above I need to find a decent monitor 21"-24" for around £120 give or take a few quid,
So any suggestions:)
I suggest this if you're after a 21.5"/22".
I have a 23" version of this, code; 23EA63. I got it for £120 around 3 months ago.
The stand is not the best but it holds the actual panel reasonably. It wobbles when you push down on it slightly on top corners. But for the cost, who cares + you're rarely, if at all gonna poke it down in the corner.
I have two of the 22 inch models and they are great, made my laptop screen look absolute rubbish! The only problem I have is that as I got them from two different e-tailers I think I got different revisions as the firmware seems a little different and the white levels aren't quite the same, which is noticeable to me as they are right next to each other but apart from that I can't fault them, well, apart from the slightly wobbly stand but once they are in position on your desk it doesn't move.
