DDR3 8Gb 1866 or 4Gb 2133 ?!
CrissTM
Hi everyone,
i have a "problem" and need some help.
I wanna upgrade my ram and i'm woundering if i should go for 8gigs @1866 RipwasX or Sniper, or go for 4gigs 2133 RipjawsX ?!
For the moment i'm using Corsair Dominator 4gigs 1600C9 (1,6v) runing @ 1740C8 (1,675v) on P55 (asus sabertooth) with i7 860 @3,8.
Or should i go with the Corsair Dominator GT 4gigs 2133, i've been using corsair for some time now and i know how good they r, including oc.
10x for ur help
What do you run the memory at? I'd imagine 1600. If so, I'd go with the 8GB 1866.
Is 4gb enough for you? If it is, then go for the higher frequency. 2133mhz will yield a higher fps count, a little but nothing major, if thats what you are after.
Well if 4gigs r enough for battlefield 3 than i think 2133's gonna b.
4 gigs is plenty when i run bf3 maxed out it takes up between 1 and 1.5 gb of total memory. Personally, id go for the 2133 and add another 4 gb kit whenever i could.
will do that, go with the 4gigs 2133.
10x for the answers
