Daytona Championship USA (AKA DUSA3)
AlienALX
Well-known member
I don't know how many of you were aware, but Sega accidentally leaked their own game last year. It can be easily made to work on a PC, given it shares the same hardware.
If you missed this and are a big fan (like me) then here is a guide that should get you up and running.
I will try and get this right. First of all you need to visit this site, as it shows you where to get it.
http://www.emuline.org/topic/1190-arcade-pc-daytona-3-sega-amusements-like-europa-r-system/
You will need to sign up, and it's French so you may need to translate.You need to download the file - SEGA_DAYTONA_UPDATE_171206 and will need Winrar to unpack it.
OK, once you have the set up file run the install. Install it to the root of a drive, under Sega. So for example, C:SEGA. Once it installs you will have your Sega folder, as well as some inside it. Look for the one called "Update" (if it is not Daytona) and if necessary rename the folder called "Update" to "Daytona".
Then you need to go into the SEGA folder DIR and then create two new folders. Name one GameData and name the other ShellData. It needs to look like this.
OK, now we need to create some INI files. I don't know if you can make them with a text file, as I simply copied one from somewhere else (FO4 IIRC) and then emptied and renamed it. In the ShellData folder you need an INI called ShellData.ini I will start with that one. In that needs to be this -
[Credit]
Freeplay = 1
[Network]
CabinetID = 1
NumCabinets = 1
Which is kinda self explanatory (puts it in Freeplay, single cab etc). OK, now go into the GameData folder and create a INI called config.ini . In that one put the following.
[Version]
Version=011217
[OpenCV]
ENABLE_CAPTURE = 1
ENABLE_TEST_BILLBOARD = 0
CAPTURE_FPS = 20
DEFAULT_CROP_X = 80
DEFAULT_CROP_Y = 40
# DEFAULT_CROP_X: 0 ~ 159
# DEFAULT_CROP_Y: 0 ~ 79
[HDR Texture]
ENABLE_HDR_TEXTURE_TEST = 0
HDR_TEXTURE_NAME = ND_T_Bgc_sky_08_10_b.cube.f16_Result.dds
[FullHD]
ENABLE_FULLHD = 1
ENABLE_FULL_SCREEN = 1
# 0: disalbe
# 1: enable
[CarBox]
ENABLE_CAR_BOX = 0
[CarTexture]
ENABLE_CAR_TEXTURE_QUATER_SIZE = 1
[Log]
ENABLE_LOG_FILE = 0
[Network]
FORCE_NET_VALID = 0
NETWORK_TYPE = 0
# 0: Slave
# 1: Master
# 2: SinglePlay
[Camera]
FOVY_RATE = 0.5
[Render]
ENABLE_DYNAMIC_RESOLUTION = 1
DYNAMIC_RESOLUTION_MAX = 1920
DYNAMIC_RESOLUTION_MIN = 960
ENABLE_DYNAMIC_MSAA = 0
ENABLE_DYNAMIC_BAKE_FREQUENCY = 1
[Reflection]
ENABLE_SKY_REFLECTION_ONLY_IN_NEW_BEGINNER = 0
ENABLE_WATER_REFLECTION_IN_NEW_EXPERT = 1
[ShadowMap]
CLASSIC_BIGINNER_SHADOW_MAP_SIZE = 1024
CLASSIC_ADVANCED_SHADOW_MAP_SIZE = 1024
CLASSIC_EXPERT_SHADOW_MAP_SIZE = 1500
NEW_BIGINNER_SHADOW_MAP_SIZE = 1024
NEW_ADVANCED_SHADOW_MAP_SIZE = 1024
NEW_EXPERT_SHADOW_MAP_SIZE = 1024
CLASSIC_BIGINNER_STATIC_SHADOW_MAP_SIZE = 4096
CLASSIC_ADVANCED_STATIC_SHADOW_MAP_SIZE = 4096
CLASSIC_EXPERT_STATIC_SHADOW_MAP_SIZE = 6144
NEW_BIGINNER_STATIC_SHADOW_MAP_SIZE = 4096
NEW_ADVANCED_STATIC_SHADOW_MAP_SIZE = 4096
NEW_EXPERT_STATIC_SHADOW_MAP_SIZE = 6144
[SpeedScale]
BEGINNER_VERYEASY_VERYSHORT = 0.7
BEGINNER_VERYEASY_SHORT = 0.76
BEGINNER_VERYEASY_MEDIUM = 0.78
BEGINNER_VERYEASY_LONG = 0.8
BEGINNER_VERYEASY_VERYLONG = 0.82
BEGINNER_VERYEASY_CLASSICMODE = 0.76
BEGINNER_EASY_VERYSHORT = 0.77
BEGINNER_EASY_SHORT = 0.81
BEGINNER_EASY_MEDIUM = 0.85
BEGINNER_EASY_LONG = 0.87
BEGINNER_EASY_VERYLONG = 0.89
BEGINNER_EASY_CLASSICMODE = 0.83
BEGINNER_NORMAL_VERYSHORT = 0.951
BEGINNER_NORMAL_SHORT = 0.96
BEGINNER_NORMAL_MEDIUM = 0.968
BEGINNER_NORMAL_LONG = 0.985
BEGINNER_NORMAL_VERYLONG = 0.985
BEGINNER_NORMAL_CLASSICMODE = 0.96
BEGINNER_HARD_VERYSHORT = 0.95
BEGINNER_HARD_SHORT = 0.97
BEGINNER_HARD_MEDIUM = 0.985
BEGINNER_HARD_LONG = 0.985
BEGINNER_HARD_VERYLONG = 0.996
BEGINNER_HARD_CLASSICMODE = 0.97
BEGINNER_VERYHARD_VERYSHORT = 0.915
BEGINNER_VERYHARD_SHORT = 0.965
BEGINNER_VERYHARD_MEDIUM = 0.985
BEGINNER_VERYHARD_LONG = 0.995
BEGINNER_VERYHARD_VERYLONG = 1.0
BEGINNER_VERYHARD_CLASSICMODE = 0.965
ADVANCED_VERYEASY_VERYSHORT = 0.7
ADVANCED_VERYEASY_SHORT = 0.74
ADVANCED_VERYEASY_MEDIUM = 0.78
ADVANCED_VERYEASY_LONG = 0.8
ADVANCED_VERYEASY_VERYLONG = 0.82
ADVANCED_VERYEASY_CLASSICMODE = 0.7
ADVANCED_EASY_VERYSHORT = 0.77
ADVANCED_EASY_SHORT = 0.81
ADVANCED_EASY_MEDIUM = 0.85
ADVANCED_EASY_LONG = 0.87
ADVANCED_EASY_VERYLONG = 0.89
ADVANCED_EASY_CLASSICMODE = 0.77
ADVANCED_NORMAL_VERYSHORT = 0.953
ADVANCED_NORMAL_SHORT = 0.953
ADVANCED_NORMAL_MEDIUM = 0.962
ADVANCED_NORMAL_LONG = 0.968
ADVANCED_NORMAL_VERYLONG = 0.97
ADVANCED_NORMAL_CLASSICMODE = 0.953
ADVANCED_HARD_VERYSHORT = 0.96
ADVANCED_HARD_SHORT = 0.96
ADVANCED_HARD_MEDIUM = 0.975
ADVANCED_HARD_LONG = 0.98
ADVANCED_HARD_VERYLONG = 0.985
ADVANCED_HARD_CLASSICMODE = 0.96
ADVANCED_VERYHARD_VERYSHORT = 0.95
ADVANCED_VERYHARD_SHORT = 0.953
ADVANCED_VERYHARD_MEDIUM = 0.98
ADVANCED_VERYHARD_LONG = 0.98
ADVANCED_VERYHARD_VERYLONG = 0.985
ADVANCED_VERYHARD_CLASSICMODE = 0.953
EXPERT_VERYEASY_VERYSHORT = 0.7
EXPERT_VERYEASY_SHORT = 0.7
EXPERT_VERYEASY_MEDIUM = 0.7
EXPERT_VERYEASY_LONG = 0.8
EXPERT_VERYEASY_VERYLONG = 0.8
EXPERT_VERYEASY_CLASSICMODE = 0.8
EXPERT_EASY_VERYSHORT = 0.77
EXPERT_EASY_SHORT = 0.77
EXPERT_EASY_MEDIUM = 0.77
EXPERT_EASY_LONG = 0.87
EXPERT_EASY_VERYLONG = 0.87
EXPERT_EASY_CLASSICMODE = 0.87
EXPERT_NORMAL_VERYSHORT = 0.951
EXPERT_NORMAL_SHORT = 0.951
EXPERT_NORMAL_MEDIUM = 0.951
EXPERT_NORMAL_LONG = 0.953
EXPERT_NORMAL_VERYLONG = 0.953
EXPERT_NORMAL_CLASSICMODE = 0.953
EXPERT_HARD_VERYSHORT = 0.93
EXPERT_HARD_SHORT = 0.93
EXPERT_HARD_MEDIUM = 0.93
EXPERT_HARD_LONG = 0.955
EXPERT_HARD_VERYLONG = 0.955
EXPERT_HARD_CLASSICMODE = 0.955
EXPERT_VERYHARD_VERYSHORT = 0.935
EXPERT_VERYHARD_SHORT = 0.935
EXPERT_VERYHARD_MEDIUM = 0.935
EXPERT_VERYHARD_LONG = 0.96
EXPERT_VERYHARD_VERYLONG = 0.96
EXPERT_VERYHARD_CLASSICMODE = 0.96
BEGINNER_CHAMPIONSHIP = 0.915
ADVANCED_CHAMPIONSHIP = 0.95
EXPERT_CHAMPIONSHIP = 0.952
[Wheel]
DEAD_ZONE = 0.1
# 0.0~1.0
PERIOD1 = 0.1375
PERIOD2 = 0.43
PERIOD3 = 0.9
FORCE1_S = 6
FORCE1_N = 8.5
FORCE1_W = 9
FORCE2_S = 1
FORCE2_N = 1
FORCE2_W = 5
# 0.0 --- P1 --- P2 --- P3 --- 1.0
# 16---F1 F1---F2 F2---1 1
GRASS_S = 3
GRASS_N = 4
GRASS_W = 8
ANGLE_PARAM = 1.125
VIB_FREQUENCY = 1
VIB_FORCE = 1
GARIGARI_FORCE_S = 3
GARIGARI_FORCE_N = 4
GARIGARI_FORCE_W = 8
Next post..
OK so you can play with the settings if you like, but if you it up just over write it with the original. Then you need to install a dongle driver on your PC. It doesn't look for a dongle, but it does look for a DLL file associated with a dongle. The file to install for that is called dk2wn3264_7.47.0.73. It can be obtained from the site I listed above. It will install the dongle driver, and the critical D2K.DLL file so that the game will run. You can get that here.
https://www.des.co.uk/support.html
OK, the next thing to do is change the compatabilty settings for two EXE files. The first one you need to do is the Daytona.EXE. I set mine to Windows 8, IIRC. Then you need to go into the Shell folder and find Shell.exe. Change that to Win 8 also (it seems Sega used some iteration of Win 8 for the arcade machine).
Then, whilst in the Shell folder run Shell.exe. Alt and Tab will close it when it is finished. Then download "Stupid Invaders" patch, you can get that here.
https://mega.nz/#!mcEViBBQ!bKObxEPRB7zH2E8J2adTJQfLK9FeYAg3YbrZlaHvu6o
You then need to install the controls file. It is called Daytona3Controls but I can not for the life of me remember where I got it (I didn't BM it it seems). I have it if you get stuck, but Google should find it.
Then you need to install the launcher. Use the one called DaytonaLaunch3.3(patched).You can get that from the first site (French one) but again I have it if you are stuck. This is very important, because otherwise there is no way to quit out of the game unless you CTRL ALT DEL and force stop it. The launcher allows you to just press Escape and exit.
Personal notes.
I did some research into needed spec but came up empty. I did, however, see it running on a RX 360? something like that (not a very high end GPU). It was running at 60hz. The game likes to run at 1080p it would seem, not sure if it scales.
The controls are a bit waffy. IDK if you have ever played Daytona on the Dreamcast? well it's like that over again. I think it is because the controller is too sharp, and it was designed to be ran on a wheel. The launcher does improve it a bit though, and it's certainly more than playable (if a little whacky at times).
You can change the difficulty, length (so laps) and etc in the config files. You can also up the resolution forcibly, but I had odd results. Oh, and you can turn anti alias (MSAA, IIRC) on and off using 1/0.
Here is a video of my first "raw" launch (no controls or launcher or full screen)
https://www.youtube.com/watch?v=4z6lyY1LJnc
One thing I will say is it's very, very pretty. It's like Sega land in glorious hi res. It's also bloody good fun too.
If my guide is a little poo then you can use this.
https://www.youtube.com/watch?v=AtHas0n5nV0
Which I sorta half used, then used another one (and then combined three together for the above :) )
Enjoy !
EDIT. To add.
If you exit the game and get a sound loop like I do (I am using Asus soundcards, known for it) then go to Device Manager, disable the audio device and then re-enable it. That will stop the sound loop.
