xDDD that box of tissues is a must in every rig buildyou should bin them though when your finished :3![]()
i like ur rig man , just the cables make it look a bit messy , but i do have to note considering u hardly got tucking away space
u did an awesome job![]()
may i suggest sum braided cables ?, would spark up that rig even more :0![]()
also like ur desk man, gotta love wooden desks![]()
just the cleenex box looks out of place on the desk ^^ , oh a cold, yeh then u definitly need em close at hand![]()
Nice rigyou might want to think about turning your heat sink so that its not just sucking hot air from the GPU... if it is getting any air at all :S it should improve your temps a fair bit if you turn it 90 degrees so that it is sucking air from the front and exhausting out the back![]()
Do you have a large enough mouse mat?
