D5 PWM Pump
tricky question, but you should be able to. i haven't used the D55 PWM yet, but
from using PWM fans wasn't really a hassle. but some users of the D5 PWM have
been having "control" issues on some motherboards and controllers. noted on
Swiftech's site for the H220 (D5 PWM isn't listed at this time) that the control
under Support - Troubleshooting has some limitations. and others have noted
the same issues on mainline mobo/controllers.
also, might drop Grey_beard (OC3D Forum Corsair section) a line on this element
of the Corsair Node control.
Why do you want to control the speed turning it up and down isnt going to make your temperatures go down and lowering the speed is just going to make them go up. That pump is pretty quiet as it is if not get the variable one and turn it down to 4 or something.
