I loaded up my benchmarking image disk, which is a boot version of XP with bare amounts of software required to run benchies. Previous score was ran on a fully loaded image which contains resource draining, Internet security and MSoffice amongst others.
Plus I managed to up the overclock to 3.14Mhz by setting fans in r507 Mach2 to 100%.
It's probably safe to say thats as good as it gets for me (probably )
Nooooo i downloaded the iso file (i only get 500mb a day bandwidth so i cant try again today) and the iso file is corrupt...it wont run might ask a kind member to post a copy of it to me....
Nooooo i downloaded the iso file (i only get 500mb a day bandwidth so i cant try again today) and the iso file is corrupt...it wont run might ask a kind member to post a copy of it to me....[img']http://www.extremeprometeia.com/forum/images/smilies/redface.gif[/img]
Try this if you get corrupt files or get kicked a lot.
Select Internet Properties (right click on the icon) - and choose settings in the temporary internet files menu. Increase the amount of space used by the temp internet files folder.
I ran into problems when downloading several hundred mb files - I found that they would corrupt or not download at all.
