Boonstick
Hi all,
I need to make some fully custom PSU cables for my Corsair AX860i PSU. I'm not intending on braiding them as the way my case is laid out (custom made case) you actually won't see any cables but the ones that came with the PSU are way too long and I need to shorten them. What is the molex pin type that I will need to remake the ends off? It will be the end that goes into the PSU itself.
Also can anyone recommend a decent shop/website where I can buy them from, preferably in the UK?
Thanks in advanced. I'll hopefully upload some pics of the system once it's al finished
