im just installing counterstrike again and i dont want to go through the updates again, does anyone know what file i will need to copy from my other, upto date pc and where i will need to copy it to?
You can use the backup utility in Steam, which creates an EXE that you run to install insead of using the disk. However, keep a copy of custom maps and saves just in case.
Iv concluded that steam sucks major balls (not related to this thread starter) The update recently dropped all my FPS and failed to send me the entire militia map, im missing half the textures and models. I copied and pasted Hams updated .GCF files over mine, and it worked, but then when i logged out of steam it wouldnt start back up again
