Crosshair V Voltage spikes?
Shift87
So today after getting my Watercooling loop going i decide to see what my temps are like while gaming, playing battlefield 3 and i start getting all sorts of voltage warnings, cpu , nb, sb, ht even hardware monitor is picking some of them up and showing insane fan speeds for fans that dont exist. here is a HWMonitor screen shot.
Circled the issues, i am fairly confident that the cpu did not reach nearly 50 volts as it would be on fire. This only happens while gaming doing anything else its fine. Anyone have any ideas whats causing this?
I also seriously doubt the CPU reached 50V, probably would've exploded tbh. It's a reading error, i get reading errors with my fan speeds sometimes with HWmonitor, so there's nothing to worry about.
The readings are coming from the same probes which is why you are seeing them in AI Suite and HWMonitor. AI Suite is notorious for showing crazy volts and sometimes HWMonitor can do the same. HWMonitor shows my CPU cooler fan at 43000+ RPM sometimes, lol.
