TheLostOne
Hey there
Well the situation is I don't know whether my Corsair AX860 power supply is capable of running two Sapphire Radeon R9-280X Vapor-X and a AMD FX 9370 CPU. I watched TTL's video about the RM450 powering a 780Ti and a i5, pretty amazing! I also saw that TTL is running a i7-3960X and a couple of Asus 7970 of an AX860i...... Sooo maybe/maybe not
Sys spec:
Asus Crosshair V Formula-Z
AMD FX 9370 @ 4,72GHz at 1.450V
Sapphire R9-280X Vapor-X @ 1100/1600 at 1.200V
1 SSD
2 WD green harddrives
8 fans total, CPU fans included
System peaked at 620W (measured of wall socket) with prime95 small FFT and MSI Kombustor running max preset 1080p
PSU calculators recommend at least 860+
If more information needed, just ask
Thanks in advance!
Sys spec:
1 SSD
