I am planning on getting another r9 270x to crossfire and I have a Corsair CX 750M psu. Will that be enough power? My cpu is a FX-8350. Nothing is overclocked.
just a suggestion but you might aswell future proof your pc and buy a 800-950w psu.
Then you wont need to take your pc apart if you wanna change your gpu to higher end like 2 r9 280xs
If his current PSU is modular then its just a case of unplugging then swapping the unit. Though it is recommended to use only the cables from the box. Still will work though.
