I guess I don't understand DNSs completely. Either way, you can always use a free DNS like http://everydns.net for all your DNS needs. Not in the mood to google so that's all you getname='Toxcity' said:hehe, Might be asking alot? Im not sure how much work goes into this kinda thing.
But does anyone know how to make your own Domain name server? :eh:
Thanks in advanced.. I am on a learning streak at the moment!![]()
name='MikeEnIke' said:I guess I don't understand DNSs completely. Either way, you can always use a free DNS like http://everydns.net for all your DNS needs. Not in the mood to google so that's all you get![]()
So run yourself a little website of you're computername='Toxcity' said:HAhaha, I know I can get free ones..
I just want a challenge, some kind of project, You know?
I have so much time at the moment..![]()
name='Nagaru' said:Firstly are you using Linux or Windows?
If you are using Linux I think opendns will do it for you.
Obviously you can't use it out on the web if you are going to change stuff.
name='Toxcity' said:Im a Windows guy..
But can Linux comunicate with Windows? I guess it can.. therefore.. setting up a Linux DNS maybe easier?
name='nunzio' said:If you are going to use it publicly, you need a static ip.
name='Rastalovich' said:`When I were a lad`, in the days of dial-up there were/was a dns.org kinda site that would change the ip in relation to u`r new allocated ip address. Something along the lines of as soon as u logged into windows/whatever and went online, it would send a message to the dns.org/site and change it each time for u. Either that or u could make a shortcut to do it.
name='Toxcity' said:If I don't have a static IP.. which I probably don't.. How would I go about getting one?
Thanks for the info so far guys!
name='Toxcity' said:Sugar.. Its not static..
Ring ring time!
EDIT: The IP only changes if I disconnect the router, right?
Could I just not disconnect the router? I mean, It hasn't been offline for ages.
So back onto the challenge!
I use this software called PowerDNS?
What does this software do? And how to work it?
