Crash report software?
Xrqute
Hi Guys,
Zeee Rig is playing up and im not entirely sure why as its currently not OC'd nothing haven't even been into the Bios since i reset it last.
I'm getting random and sparattic Reboots/Crashes. Just out of no where my rig is rebooting itself. i haven't been able to pick a pattern as to what is causing it so i was wondering is there some sort of software that would report on the cause of a crash/random reboot?
it's been doing it the last couple of days and now its really starting to annoy me so ive gotta get it sorted >.<
No BSOD's. its literally like someone hits the reset button.
Are you running under water?
The same happend to me when water leaked on the motherboard, it would just randomly restart.
Also, on first glance can you see something making contact with the motherboard that could cause a short circuit?
I also assume that you used standoffs, right?
of course i use stand offs lol and yea running water.
PSU falling down, faulty Motherboard, bad front panel IO connections...
I'd say with Error ID:41 it's more than likely your PSU.
I had an error 41. It can mean anything. Check all connections. I found my sata cable was loose and the lock broke. Switched it out and problem solved. It was causing a short.
Also make sure you ONLY use the cables that come with the PSU. Other cables are not guaranteed to always work properly. Found that out the hard way too.
