K kenny01924 New member Jan 29, 2012 #1 i was thinking of getting either a corsair h100cpu cooler or the h80 by the same company ive read a few reviews and just wondered which one would you pick
B BaMb1N0 New member Jan 29, 2012 #2 go for the H100 if you have the mounts in your case. may have to consider getting other fans either way because the OEM ones are noisy. have you seen tom's review on the H100?
E EliteGBR New member Jan 29, 2012 #3 All depends on your case, the h80 fits well as a rear exeust, but if you have the room get the h100 and mount it to the roof
K kenny01924 New member Mar 7, 2012 #5 BaMb1N0 said: go for the H100 if you have the mounts in your case. may have to consider getting other fans either way because the OEM ones are noisy. have you seen tom's review on the H100? Click to expand... thanks for that il get the h100
