CPU Cooler + fans
hellkilleR
So after 2 weeks that i got my pc I am searching for a cpu cooler + case fans. As a cpu cooler I was thinking of getting the coolermaster hyper 212+. I was searching the web and found 2 different versions:
1: http://www.coolermaster.com/product.php?product_id=6603
2: http://www.coolermaster.com/product.php?product_id=6636
I am thinking to assemble 2 custom 120mm fans. Which do you suggest to get?
As for case fans I need 5x120mm (3 for the top and 2 for the cpu cooler) and 2x140mm (1 for the back and 1 for the bottom). For the 140mm i was thinking to get these ( http://www.corsair.com/us/cpu-cooli...140-quiet-edition-high-airflow-140mm-fan.html ). For the 120mm I don't know what to get. What do you suggest?
