Corsair Obsidian Series® 350D Consumer Review
Status
Not open for further replies.
Kopesetic
Corsair Obsidian Series® 350D mATX Chassis Consumer Review
Author's Note
For those looking for a fully detailed product review, I would direct you to Corsair's product listing or TTL's video review, both of which will be linked at the bottom. This is meant to be a consumer review so all details will not be covered.
Today we take a look inside Corsair's new MiniMe, the Obsidian Series® 350D. This pint-sized Obsidian marks the first micro ATX case released by Corsair and once again, they don't disappoint. The Obsidian 350D was designed to deliver high-end performance and cooling potential for IT enthusiasts in a compact shell and that's exactly what you get. Let's dive in and see what Corsair has in store for us.
First Impressions
I recently purchased this case to begin my personal system over-haul. I've always preferred micro ATX setups and I'm a bit of a Corsair fanboy so this case caught my attention from the start. First, the case looked smaller than advertised on the product listing. As soon as it was unboxed, my mentality changed completely. I had more than enough work-space and room for my hardware. It was in prefect shape when it arrived and included all advertised components. The 120mm and 140mm fans that came with the case worked flawlessly. It truly was all they claimed. However, The first issues I ran into with the case was the front fan filter, front detachable panel, and 2.5" SSD bays. While I enjoy the design and convenience of air filters, I feel they could have done a better job with securing the filter as it sits quite lose, falls out without much pressure, and can be difficult to reattach at times. The front detachable panel covering the filter is quite sensitive to pressure as well. While moving the case around the cover would constantly detach from very little pressure so I would advise taking the panel and filter off while moving the case around or working on it to avoid damage. Additionally, the SSD bays are quite difficult to separate and you'll probably need some kind of tool to help. I used needle-nose pliers to release the locks which seemed to work well without damaging anything. Other than that, I would say you couldn't ask for much more out of a micro ATX chassis as it offers so much in terms of performance potential. Let's move on and take a closer look at some of the features.
Techinical Specifications
Along with a variety of other features, the Obsidian 350D comes equipped with a 2-year warranty, compliments of Corsair. The case measures 17.7" long, 8.3" wide, and 17.3" tall, allowing builders plenty of room for extra long graphics cards, tall CPU coolers upto 160mm, and custom water-cooling setups. With room for two 240mm radiators, top and front, and with Intel's recent release of the Haswell architecture accompanied by a wide variety of high-performance mATX z87 motherboards, this chassis has the potential to become a pint-sized powerhouse. I would also note that if you plan to use a 240mm top radiator or an H100i, you lose the ability to mount an optical drive in the top 5.25" bay. However, you can still mount short back-end controller panels, such as a multi-fan controller, so you don't totally use the bay.
Expandability is usually the main concern when looking at a micro ATX case, or atleast it is for me. Corsair did a good job of maximizing expandability and graphics potential on this one. The 5 expansion slots and room for upto 380mm GPUs allows for dual GPU setups without using all the bays and the front 140mm fan creates a nice airflow over the GPUs. Of course, this would be dependent on the motherboard used and any other add-in cards you might plan to use, but it's nice to see an mATX that has decent graphics expandability.
Although the product is listed as only having two 2.5" internal SSD bays, it actually comes with three. In addition to the three SSD bays, the 350D comes with two 3.5" HDD bays and two 5.25" optical bays. Obviously, some custom watercooling kits with dual-bay pumps will prevent builders from being able to use optical drives. Also, I had an issue getting the 5.25" bay tool-free lock to clamp down. I was able to get the clamp locked down but it took several minutes and a lot more effort than there should have been. Seems the standouts for securing may be a little too thick for some optical drives.
Another concern I had initially was how the cable management would turn out with my non-modular PSU given that this is an mATX case. Yet again, Corsair put my worries to rest. With almost 1" of space behind the motherboard tray and multiple tie-down points, including a long awaited CPU power connector tie-down, cable management was a breeze. I would imagine that if I could achieve this with a non-modular PSU, builders using modular, or even semi-modular power supplies, can expect no problems when routing cables. Additionally, this chassis can support upto 180mm ATX power supplies so getting enough power into this case for your hardware shouldn't be an issue.
While the Obsidian 350D does have some restrictions, they are minimal in comparison to what builders can achieve from this product. The sturdy construction of the case, although not as sturdy as it's Obsidian big brothers, is a testament of Corsair's quality and design. Also, with this beauty retailing for $110 US (€83 Euro), it offers high-performance quality at a great value and is competitively price with it's only rival (in my opinion), the Fractal Design Arc Mini.
Resources
Corsair Obsidian 350D mATX Chassis Product Listing
TTL's Corsair Obsidian 350D mATX Video Review
This is more of an overview than a review.
Not much in terms of personal experiences. The 'First Impressions' section is about all there really is on personal experience, and excluding that, pretty much all of the rest of it could have been done by just looking at the spec sheet.
Also, the 'First Impressions' section actually comes across as more of a conclusion, and I don't feel that you really go into depth about the problems there.
Infact, in that paragraph, you don't specifically say a single positive thing about the product, yet finish the paragraph with:
'Other than that, I would say you couldn't ask for much more out of a micro ATX chassis.'
Probably should have taken a little more time on it and read it over several times IMO.
You do speak the truth. This was meant to be more of an example of my writing style and literacy more than anything. I suppose I should have taken a little more time and gone further in depth on the problems I spoke of. Additionally, I haven't had the chance to try any watercooling or other hardware testing in it yet so I'm pretty much just going off what I've experienced so far.
Edit: Did a quick revise and addressed a few concerns. Also revamped certain areas to include a little more personal context.
Hate to point this out matey but if you cant take your own photos youll never be any good to me. And technically you should be doing everything as your own not using other sources and reviews for info.
I can take photos, just didn't think it was vital for this particular work. I understand some of what I wrote can be found in other reviews but at the same time, it's obvious things you don't need a review to know anyway. This was meant to just give you an idea of what I can do written wise. Nothing is copy and pasted, the experiences spoken of are all my own and things that you can see just from looking. I suppose I could work up an actual review, one not meant as an example, with my own photos etc. I was just treating it like an audition I guess you could say.
No mate its meant to be a full application, not give you an idea and use stock images.
Thanks but this isnt up to standard and you obviously have not taken it seriously enough.
I appreciate your comments, but I'm not willing to give up that easy. I'm going to rewrite this review with only my first hand experience, including my own pictures if that's what you want. But there will still be details you can find in other reviews because I have had the same issues others have reported from the case. It certainly won't be copy and paste just as the original wasn't.
Gee, Tuff Crowd!!! I liked the Review/Introduction...To bad I didn't see this review before shelling out the $US for the 650D...I suppose I will just have to build two computers now...I REALLY like the 350D package!
Thank you for the Review!
Well, this is for a serious cause so I would expect criticism. I figured I was being serious, but it looks like not quite serious enough. This is not a problem for me since I know exactly what they want now. Tbh, I kind of took the "you don't have to buy anything, just has to be your own work" out of context. But that's still no excuse for not putting forth my absolute best effort initially and using my own pictures.
I'm glad you found the review helpful though. Always glad to hear that.
TBH mate you need to start again. Theres not enough text, stuff missing and well. Id never accept anything like this.
This is like an article or news item its not a review.
Working on it now. I get what your saying and when I think about it you're right. I should go further in depth on what I addressed because it does seem like I'm just parroting back details from other reviews and the tech specs. Also, this really doesn't give readers a detailed idea of what to expect since it was meant to be an example. I'll try not to disappoint on the next version.
Working on it now. I get what your saying and when I think about it you're right. I should go further in depth on what I addressed because it does seem like I'm just parroting back details from other reviews and the tech specs. Also, this really doesn't give readers a detailed idea of what to expect as it was meant to be an example.
Im not after examples mate.
You need to imagine you, we, everyone has never seen this before.
Including you NOT looking at other reviews for help. Thats cheating and lets face it, some stuff we cant do that anyways so relying on it now is silly.
Should I just edit this or create a new review and let you guys remove this? Also, was the grammar and writing style up to standards or should I work on that more as well?
Status
