most use the H50 as it is been around for a while and can be had for cheap. if i
were to do one, it'd be the H60 or H80 with the thin pump mount. the H100 is overkill
for that particular mod. the radiator is a PITA to mount in most cases.
there is usually a 120 mount in the floor ready for a rad for the GPU.
ive even seen where they change the hose and add a reservoir, but usually in
vain as the kit usually dies afterwards because of the added tubing length and openness.
airdeano
