Corsair 380T GPU?...
Dawelio
Active member
Heya guys,
I'm a bit confused here over the numbers, can or can not a Gigabyte 980Ti G1 Gaming or a Sapphire R9 390X Nitro fit inside a Corsair 380T?.
Do you know any other semi-passive high end GPUs that can fit inside of it?... Preferably with 3 fans rather than 2 and as much black colour as possible. MSI's red and black is kinda out of the question.
Thanks,
Chrazey
AFAIK the Nitro is only for the 390. Tri-X is only for 390x.
According to Cosair it supports upto 290mm. The G1 and Nitro/Tri-X are over the limit by 20mm or more.
Ohh well my bad, just liked the look of the Nitro, that's all and that it would fit in better than most. And also not being too old, like an R9 290X Vapor-X or so.
I haven't slept all night, so my eyes may've seen ghosts... but I read that the G1 iw 209,5mm?... Can't believe that 0,5mm makes it not fit :(, may any modding help perhaps?.
EDIT: Since this is what got me thinking...
attachment.php
Not quite sure what gpus those are and therefore the measurements of them though.
