Corsair 250D Fan question
Dawelio
Active member
Hey guys,
I know that some in here have the Corsair 250D mini-ITX case and I want to ask you an odd question...
The 250D is capable of having an 240 radiator, such as the H100i, on the side.
But with it installed, is it possible to have a 200mm fan in the front, as an in take fan, such as the BitFenix Spectre Pro... or will it be too tight?
Thank you!
Regards,
Chrazey
Hi
I have a 250D with an H100 in the side as shown in Tom's review.
http://www.overclock3d.net/reviews/cases_cooling/corsair_obsidian_250d_itx_case_review/1
I don't think anything other than a 140mm fan will fit in the front
--Rick--
Thanks for the reply!
And dang it then!... so there's no way to actually fit an 200 fan in the front with an h100i in there?... not without modding the H100i, off to the side a bit more, if that's even possible? (if you get what I mean here...)
I will post in this already existing thread, instead of creating a new one...
What I want to ask you guys, for those who do have the 250D and for those who doesn't.
What would the best/optimal way to configure your fans on the H100i?...
Exhaust or intake and in push or pull?...
Thank you!
