Just a real quick note to say this combo DOES work. It's very tight, but there is an OK gap between the heat pipe and the top of the case, although it does mean you have to remove the drive bay mount as it goes where the heat pipe wants to be. Plus the PCI cables have to be wrapped pretty tight back so you can get the case on but they're fine once in place.
Been playing Frontier Dangerous on this with a 4790K@4GHz (for now) and some 16Gb Vengeance Pro, amazingly capable setup, unless I need four slots or SLI I don't think I'll be going back to ATX.
Heatpipe a couple of mm over the side brace
Time to remove the external drive mount
