copper plate?
a copper block might, but if it is too big then the heat wont disapate into the actualy heatsink, it will just stay in the copper block. would be ncie to try though.
name='harmonicgen007' said:
if i got a small copper plate and put it on the bottom of my heatsink would it work better lol?
Possibly, a lot of cheap-o heatsinks have copper blocks attached to their aluminum bases to help aid in dissipation. I guess u could try, but u'd have to make sure that it doesnt lift the HSF too far up or you wont be able to latch it down.
yeah i know, is there such thing as thermal glue?
yeah okk artic silver are the ownage of everything :D
The last thing u'd ever want to do is use thermal adhesive to attach a heatsink to ur processor, because it's never comin' off, lol... and if u do get it off, it's takin shit with it, more than likely the IHS if u have one, if u were retarded enough to attach it directly to the die on an exposed die proccy then say buhbye to the core! lol
short answer no it would have to be physically connected(with 100% matched surfaces -- impossible) to the heatsink to dissapate heat any better else it will do quite to opposite (even with tim tween the HS and copper it will still be lower performance) sorry man has to be the same metal (or soldered perfectly) to increase performance
Basically it would be best to buy a decent HSF cause unless you're an expert metal workerthen it will turn out shit!! :D :eek:
hmm yeah i see, im not actually going to do it im just seeing if it would work lol
ahh i loved science hated evry other subject tho <esp computers it was more like ms office studies>
