Mysterae
Need your help guys! This is the last thing I need to sort out for the watercooling of my system.
I need to work out how to connect chromed copper tubing to a bulkhead (case wall) then to a quick disconnect, for normal plastic tubing.
I'd prefer the connector at the end of the chromed copper tube to be a push-fit type; makes installation much easier, but if it has to be compression then so be it.
Hopefully the image below will help explain:
Cheers.
Cheers.
