Coolits 30% off trade in! I have a FREEZONE ELITE!
bullcrew
First off they are offering up to 30% off with the trade in of an old cooling system to try help us peeps out with the new stuff and the launch of it.
Im looking into a sli cooler for the front end or the BOREAS (MONSTER OF COOLING) for my Cosmos case coming in
http://www.coolitsystems.com/
I frosted a cpu with the eliminator and was hooked with there products so I opted for a Quad and needed to up the cooling so i got ahold of them and was lucky enough to get a FREEZONE ELITE unit for Beta testing. So for over a month now and runs of 3.9ghz to 4.1 so far the temps arent my problem on the CPU. I did a dead test of it to see where it was and what it could cool so I took the CPU to 4.1 and railed a 1.67v through it to see temps and they got to 67 degrees (90 in shop). Then I had the issues of overheating my cooling pipes (NB) so now I need to do a bolt mod and some AS5 between contacts to plain it for cooling. (went black and whacked out) But wasnt my cpu temps they were in control!
It has 250 watts of cooling before lapping a CPU and HS or adding cxase fans so its potential is incredible with several ways to make it more effective as needed. Not that i have had a need to further its cooling but its got definate headroom on a quad.
It runs on medium 95% of the time Hi is a little too much unless OC'n then I bump it up for the heavy voltage runs. This thing could do a OC's C2D and a 8800 at the same time without issues. So if you run a quad OC'd its great and if you run a C2D and a 8800 OC'd but need more cooling they can custom plumb them for you.
