Cooling Radiator
hardw1re
I've been having idea's and designs popping into my head the last few days, this is just a suggestion. well sometime ago i tried to build a copper piped water cooling for my cpu, it actually worked for a while, until where i'd bodged a connection between the copper pipes and the plastic tubing, enough of that though.
You can get some really good 8mm copper piping, and then some 90 degree bends. The idea is that, to produce a simple back and forth piping to sit inside the case with cold water pumping round it to act as a radiator and cunduct the heated air lowering the temperature of the air. I had a similar idea to place piping around the compressor of my mach 2 to try and radiate some of the heat out of the compressor.
| ________________|
| |_________________
| _________________|
| |_________________
| _________________|
| |_________________
|__________________|
