Think i originally posted in the wrong section, sorry admin
Firstly heres my spec:
AMD Am2 6000+ 3.01Ghz duel core
Zalman 9700 pure copper cpu cooler
Asus cross hair mobo
corsaire dominator 2x1gig 800mhz
550w arctic PSU
2x 128mg xfx geforce 6600gt SLI
one 500gig hdd SATA2
2 of these case fans http://www.specialtech.co.uk/spshop/...cat=525&page=1
one as an inlet at the front of my case and one as an exhaust at the top rear
I HAVE NOT OVERCLOCKED THIS SETUP IT IS ALL FACTORY SETTINGS
When ive been using my pc for a while if i check the cpu temps in the bios its usually around 50 degrees and the cooler spins at around 3125rpm the mobo temp is usually around 10 degress cooler than the cpu.
Is this about normal for my setup as my system seems quite noisy compared to before i upgraded it. i thought buying that really good zalman cooler would keep the npise down, and i bought my case fans as they are pretty much silent, and my psu doesnt make much noise.
should i consider other cooling options like a northbridge heatsink or something as i would really like to make my pc quieter?
when i built my pc i made sure all cables were routed well out of the way to optimise airflow.
cheers guys
550w arctic PSU
cheers guys
