zan76 New member Sep 27, 2011 #1 hi guys just want to double check iam a few days away from ordering a 570 and i want to check if i can use my Coolermaster Silent ProM 700W
zan76 New member Sep 27, 2011 #3 SieB said: Yes Click to expand... thx sieb even with a overclock of 4.5 with 1.36 volts
yassarikhan786 New member Sep 27, 2011 #4 I'm running a factory overclocked 580, which draws more power than a reference (duh) 580, so you should have no problem with the 570 and the overclocked CPU .
SieB New member Sep 27, 2011 #5 zan said: thx sieb even with a overclock of 4.5 with 1.36 volts Click to expand... Yeah, should be fine.
