A few months ago I purchased a Coolermaster ATC 500 from an auction site, my original plan was to have the case anodised and to make a rather nice Project case.
When I received the case I found the side panels have some sort of coating, because of this the case has sat unused for some time, I think its about time to rectify this and find a way to clean the case up.
Can anyone recommend a plan of action?
My current plan is to either have the side panel’s plain aluminium or to have them anodised like originally planned. If I have them anodised this would mean the side panels would have to be 100% clean of all the coating, this would rule out sanding as the clips on the inside of the door that slide over the case chassis would be impossible to sand.
With that in mind I am currently thinking along the lines of a dip tank, or some sort of solvent to clean it up.
Anyone recommend a product or website of a place that may be able to help?
Any help or advice is much appreciated.
