Cooler question
WeskerPG
i bought : Click Me
that cooler
but my temperature changed from 27° (standard cpu cooler) to 30-31° with the new cooler or heatsink.
is it normal ? or should it be lower.
it has 3 fans and i thought it would be lower
sabertooth z87 - mobo
So yeah thats my question, ty.
it has 1150 socket.
If it's a rubbish cooler with rubbish fans then yes the temps could go up, try a better thermal paste and try remounting it use NT-H1 or MX4 and see if that helps if not put the original fan back on get a refund on the cooler and buy something like the Coolermaster 212, hope this helps
Hmm, idle temps don't really mean much; sometime an idle can be a couple degrees warmer but the load temp will be ~10-15 less.
Just had a look at it and yeah it looks super cheap, the amount of fin space is very small :/
Still worth checking the load temps but if they're really bad then just return it.
well it didnt change like i wanted to, i put back the old one (standard) and i used the other fans on the case, i had to do something with them LOL, well w/e i learn my lesson
