WeLikeLead
Hi all,
Cooler Master has just unveiled their most advanced Air cooler to date (and some would argue 'ever')
Model RR-V8VC-16PR-R1
CPU Socket Intel® LGA 2011/1366/1156/1155/1150/775
AMD FM2/FM1/AM3+/AM3 /AM2
Dimensions 154 x 149.8 x 166.5mm (6.1 x 5.9 x 6.6 in)
Heat Sink Dimensions 154 x 140 x 153.5mm (6.1 x 5.5 x 6.0 in)
Heat Sink Material Vapor Chamber / 8 Heat Pipes / Aluminum Fins
Heat Sink Weight 854g (1.9lb)
Heat Pipe Dimensions Ø6mm
Fan Dimensions Ø 140 x 20 mm (5.5 x 0.8 inch)
Fan Speed 600 – 1,600 RPM (PWM) ± 10%
Fan Air Flow 28 – 82 CFM ± 10%
Fan Air Pressure 0. 3 – 1.45 mmH2O ± 10%
Fan Life Expectancy 160,000 hrs
Noise Level 16~36 dBA
Bearing Type POM bearing – Cooler Master 4th Gen. Bearing (*POM = Polyoxymethylene)
Connector 4-Pin
Rated Voltage 12 VDC
Rated Current 0.31A
Power Consumption 3.72W
Fan Weight 110g (0.24 lb) x 2
TDP 250W
As you can see with a TDP of 250W it is currently the most powerful air cooler I know of. If any one else knows of a cooler that can reach that post it up
Thanks,
Connector 4-Pin
Rated Current 0.31A
TDP 250W
Thanks,
