The phrase you were looking for is 'HAF... Arsed'. There seems to be something in the Cooler Master house ethos to get to a plateau of goodness and then fall off the mountain altogether. Rubbish? Not HAF! How the hell can you name a case as Hgh Air Flow and NOT design it around the fans that make it so? How can you name a case HAF and fail to deliver the aesthetic associated with the name? It would serve them right if Thermaltake ripped this off... and did it properly!
As I wrote, this appears to be a brand defect. I'm just in to disassembling to re-orientate a C700M and noticing build & execution quality problems that are just... I was going to write juvenile; but they would put a youngster to shame. Some of that comes from tacking obvious-when-you-get-close plastic aesthetic pieces on a metal box skeleton. The execution of the aesthetics was much, much, better on the Cosmos II. Sloppy seems to be CM's middle name aesthetics-wise, and needlessly letting form get in the way of function.
This HAF 500 looks to be a nadir of inexcusable god-awfulness. The depths have been reached when I can suggest Thermaltake could do better. CM seem to have no long-term corporate memory of their own errors and no long-term awareness of the rest of the market, their mistakes, and recovering from those mistakes. Nevermind an inability to recognise reviewer's constructive criticisms; and nevermind take them on-board.
Perfect case for sticking a RTX 3080 12GB or RX 6500 XT in though. 'Be The Steaming Pile Of Odure You Dream You Are' seems to be the motto de jour.
