Connector / Power questions..
Winther
Hey!
Im in the middle of a build and have a few questions as electricity isnt really something I know alot about..! :)
I bought a LED station for 20 LEDs from mod/smart. its only 2 pins as you can probably guess, but can I run 7 fans, 2 pumps and 6 LEDs from that? it gets power from a 4 pin power connector (commonly referred to at molex).
should also say that the pumps are the small ceramic pumps from alphacool :)
Yeh - absolutely fine. Most psus come with 4 molex connectors per cable and so it doesnt make any difference whether you wire them all into 1 port, or split it between the 4 as they all go to the same place.
You can only overload the rails - not the ports themselves
ofcourse your right..!
another quick question.. can you get some of those small connectors like those from the power/reset switch in the frant panel? and if so, where?
btw, which two cords are used in a fan and why are there 3 when it doesnt have any LEDs?
ehm.. what I mean is: there are 3 wires comming from my noctua fans but the LEDs I have there are only 2.. so isnt one of the fan wires "not needed" so to speak?
I really dont know anything about that so its probably an idiotic question..
they dont have those connectors sadly... :/
