Indeed, was thinking the same. Lukcily this battery is fine, you should really let your battery go dead before charging again. When you are using the laptop via mains, remove the battery.
I always drain to about 10%, when my laptop gives a warning and charge overnight or in the evening too 100% and take it out asap after. I also remove it when using the laptop with mains like mentioned earlier.
