Computer Acronyms V-Z-#
JN
V
<pre>
VA Virtual Address + Visual Age [IBM]
VAD Value Added Dealer
VADD Value Added Disk Driver
VADSL (See DSL)
VAI Video As Input
VAL Value + Voice Application Language
.VAL Validity Checks (file name extension) [Paradox]
VAM Virtual Access Method
VAN Value Added Network
VAP Value Added Process
VAR Value Added Reseller + Value Added Retailer + Variable
VAST Variable Array Storage Technology
VAX/VMS Virtual Address Extension/Virtual Memory System [DEC]
VB Variable Block + Visual Basic [Microsoft]
VBA Visual Basic for Applications [Microsoft]
VBE/AI Vesa Bios Extension/Audio Interface
VBI Vertical Blanking Interval
VBNS Very High Speed Backbone Network Service [MCI + NSF]
VBR Variable Bit Rate
VBRUN Visual Basic Runtime
VBS Visual Basic Script
.VBX Visual Basic Extension (file name extension)
VCC Virtual Channel Connection
VCD Video Compact Disk + Virtual Communications Driver
VCI Virtual Circuit Identifier
VCL Visual Class/Component Library
VCM Virtual Channel Memory
VCN Virtual Cluster Number
VCOS Visual Caching Operating System [AT&T]
VCPI Virtual Control Program Interface
VCR Video Cassette Recorder
VDD Virtual Device Driver
VDDM Virtual Device Driver Manager
VDE Video Display Editor + Visual Development Environment
VDI Virtual Device Interface
VDISK Virtual Disk
VDM Virtual DOS Machine [IBM]
VDMAD Virtual Direct Memory Access Device [Microsoft]
VDS Virtual DMA Services
VDSL (See DSL)
VDT Video Dial Tone + Video Display Terminal
VDU Video Display Unit + Visual Display Unit
VEGA Video-7 Enhanced Graphics Adapter [Video-7, Inc.]
VEMM Virtual Expanded Memory Manager
VEMMI Versatile Multimedia Interface
VER Verify + Version
VERONICA Very Easy Rodent-Oriented Net-Wide Index to
Computer Archives [Internet]
VERR Verify Read Access
VERW Verify Write Access
VES Video Encoding Standard [Oracle] +
Virtual Execution System
VESA Video Electronics Standards Association
VF Virtual Floppy
VFAT Virtual File Allocation Table [Microsoft]
V.FC Version.First Class (communications standard)
VFD Vacuum Fluorescent Display
VFW Video For Windows [Microsoft]
VGA Video Graphics Array
VGC Video Graphics Controller
VHDL VHSIC Hardware Description Language
VHF Very-High Frequency
VHS Very High Speed + Video Home System +
Virtual Host Storage
VHSIC Very High Speed Integrated Circuit
VI Visual Interactive (editor) [UNIX]
VIA Virtual Interface Architecture [Intel]
VIE Virtual Information Environment
VIF Virtual Interface + Virtual Interrupt Flag
VIM Vendor Independent Mail +
Vendor Independent Messaging + Video Interface Module
VIO Video Input/Output + Virtual Input/Output
VINES Virtual Networking System [Banyan]
ViP Visual Programming [Lotus]
VIP Variable Information Processing +
Video Information Provider +
Virtual Interrupt Pending +
Visual Interactive Parser
VIPER Verifiable Integrated Processor for
Enhanced Reliability
VIS Video Information System [Tandy] +
Viewable Image Size +
Visual Instruction Set [Sun] +
Voice Information System
VJ HEADER Van Jacobsen Header (compression) [Unix]
VLA Variable-Length Array
VLAN Virtual Local Area Network
VL-BUS Vesa Local-Bus [VESA]
VLD Variable-Length Decoder
VLF Very Low Frequency
VLINK Visited Link
HTML:
VLIW      Very Large Instruction Word
VLM       Virtual Loadable Module
VLSI      Very Large Scale Integration
VLSIPS    Very Large Scale Immobilized Polymer Synthesis
VLT       Variable List Table
VM        Virtual Machine + Virtual Memory
VMA       Virtual Memory Address
VMB       Virtual Machine Boot
VMD	  Video Motion Detection
VME       Versa Module Eurocard +
Virtual Memory Environment
VML       Vector Markup Language [Microsoft]
VMM       Virtual Machine/Memory Manager
VMOS      Vertical MOS
VMP       Virtual Modem Protocol
VMS       Virtual Machine Storage + Virtual Memory System +
Voice Message System
VMT       Virtual Memory Technique
VNA       Virtual Network Architecture
VNC	  Virtual Network Computing
VNOS	  Visual Network Operating System
VOC       Creative Voice (format) [Sound Blaster]
VOD       Video On Demand
VOFDM	  Vector Orthogonal Frequency Division
Multiplexing [Cisco]
VOIP      Voice Over Internet Protocol
VOL       Volume
VOM       Volt-Ohm-Milliammeter
VOR       Visions Of Reality
VOS       Verbal/Virtual/Voice Operating System
VP        Virtual Path
VPD       Virtual Printer Device + Vital Product Data [IBM]
VPDN      Virtual Private Data Network
VPDS      Virtual Private Data Service [MCI]
VPE       Video Port Extensions [Microsoft] +
Visual Programming Environment
VPL       Virtual Programming Language
VPM       Video Port Manager
VPN       Virtual Page Number + Virtual Private Network
VPS       Voice Processing System
VPSC      Vault, Process, Structure, Configuration
VPT       Virtual Print Technology [Dataproducts]
VR        Virtual Reality + Voltage Regulated/Regulator
VRAM      Video Random Access Memory
VRD       Virtual Retinal Display
VRE       Voltage Regulated Extended
VRM       Vendor Relationship Management + Voltage Regulator Module
VRML      Virtual Reality Modeling Language
(originally named Virtual Reality Markup Language)
VROOMM    Virtual Real-time Object Oriented
Memory Manager [Borland]
VRRP	  Virtual Router Redundancy Protocol
.VRS      WordPerfect Graphics Driver (file name extension)
VRT       Voltage Regulation Technology [Intel]
VRU       Voice Response Unit
VS        Virtual Storage
VSAM	  Video Surveillance and Monitoring +
Virtual Storage Access Method
VSAT      Very Small Aperture Terminal
VSE       Virtual Storage Extended
VSF       Vertical Scanning Frequency
VSI       Virtual Socket/Switch Interface
VSIO      Virtual Serial Input Output
VSM       Virtual Shared Memory + Virtual Storage Management +
Visual System Management [IBM]
VSN       Volume Serial Number
VSOS      Virtual Storage Operating System
VSWR	  Voltage Standing Wave Ratio
VSYNC     Vertical Sync
VT        Vertical Tab
VTAM      Virtual Telecommunications Access Method [IBM]
VTNS      Virtual Telecommunications Network Service
VTS       Volume Tracking Driver
VUI       Video User Interface
VUP       VAX Unit of Performance
VWB       Visual WorkBench [Microsoft]
VWM       Virtual Window Manager
VXA       Variable-Speed Architecture [Ecrix]
VxD       Virtual Extended Driver [Microsoft]
.VXD      Virtual Device (file name extension) [Microsoft]
VXML	  Voice Extensible Markup Language
V&V       Verification and Validation
</pre>
[SIZE=7]W[/SIZE]
<pre>
W/        With
W3        (see WWW)
W3A       World Wide Web Applets
W3C       World Wide Web Consortium
W4        What-Works-With-What
WAAS      Wide Area Augmentation System
WABI      Windows Application Binary Interface [SunSoft]
WAE	  Wireless Application Environment
WAI	  Web Accessibility Initiative +
Web Application Interface [Netscape]
WAIS      Wide Area Information Server
WAITI     Wait-For-Interrupt
WAITS     Wide Area Information Transfer System
WAN       Wide Area Network
WAP       Wireless Application Protocol
WAR	  Web Archive
WARP	  Web Service Aggregtion, Rely and Propogation
WATS      Wide Area Telecommunications Service
.WAV      Waveform Audio (file name extension)
WBEM      Web-Based Enterprise Management
WC        Word Count
W-CDMA	  Wideband CDMA
WCS       World Coordinate System
WD-40	  Water Displacement-40th Attempt
WDDX	  Web Distributed Data Exchange
WDL       Windows Driver Library [Microsoft]
WDM       Wavelength Division Multiplexing +
Windows Driver Model [Microsoft]
WDRAM     Windows Dynamic Random Access Memory
WEA	  Web Enabled Application
.WEB      Entities Emphasizing the WWW (Domain Name) [Internet]
WEBDAV	  Web Based Distributed Authoring and Versioning
WEBNFS    Web Network File System [Sun]
WEFT	  Web Embedding Fonts Tool [Microsoft]
WELL      Whole Earth 'Lectronic Link (BBS)
WEP	  Wired Equivalent Privacy +
Wireless Encription Protocol
WFM       Wired For Management [Intel]
WFQ	  Weighted Fair Queuing [Cisco]
WFW       Windows For Workgroups [Microsoft]
WGS       Work Group System
WHAM      Waveform Hold and Modify [Microsoft]
WHC       Workstation Host Connection
WIB	  World wIde weB (suggested oral replacement of
nine-syllable 'WWW' using one-syllable 'WIB'
WIFI	  (Wi-Fi) Wireless Fidelity
WIM	  Wireless Instant Messaging
WIMP	  Windows, Icons, Menus and Pulldowns
WIN 9.X   Windows95/Windows98
WIN...CE  Windows Compact Edition [Microsoft]
WINDBG    Windows Debugger [Microsoft]
WINE      Windows Emulator
WINForum  Wireless Information Networks Forum
WIN...MCE Windows Media Center Edition [Microsoft]
WIN...ME  Windows Millennium Edition [Microsoft]
WINS      Windows Internet Naming Service [Microsoft]
WIN...SE  Windows Second Edition [Microsoft]
WINSOCK   Windows Open Systems Architecture [Microsoft] +
Windows Sockets
WINWORD   Word For Windows [Microsoft]
WIN...XP  Windows The "Experience" [Microsoft]
WISE      WordPerfect Information System Environment
WISP	  Wireless Internet Service Provider
WIT       Web Interactive Talk [Internet]
.WKB      Workbook (file name extension) [WordPerfect]
.WKE      Worksheet (file name extension) [Lotus 1-2-3] [LDC]
.WKQ      Spreadsheet (file name extension) [BORQU]
.WKS      Worksheet (file name extension) [Lotus 1-2-3] [LDC]
.WKZ      Compressed Spreadsheet (file name extension) [BORQU]
.WK1      Worksheet (file name extension) [Lotus 1-2-3] [LDC]
WL        Word Line
WLAN	  Wireless Local Area Network
.WLG      Dr. Watson Log (file name extension)
WLL	  Wireless Local Loop
.WMA      Windows Media Audio (file name extension) [Microsoft]
WMC       Workflow Management Coalition
WME	  Wireless Multimedia Enhancements
.WMF      Windows Metafile Format (file name extension) [Microsoft]
WMFSDK	  Windows Media Format Software Development Kit [Microsoft]
WMI	  Windows Management Instrumentation [Microsoft]
WML	  Wireless Markup Language
WMP	  Windows Media Player [Microsoft]
WMRM      Write Many, Read Many
WMT	  Windows Media Technologies [Microsoft]
WNIC      Wide-Area Network Interface Co-Processor
WNIM      Wide-Area Network Interface Module
W/O       Without
WORM      Write Once, Read Many
WOS       Workstation Operating System
WOSA      Windows Open Services/Systems Architecture [Microsoft]
WOW       Window On Windows [Microsoft]
WP        WordPerfect + Word Processing + Write Protected
WPA	  Wi-Fi/Wireless Protected Access
.WPD      Windows Printer Description (file name extension)
.WPG      WordPerfect Graphics (file name extension)
WPHD      Write-Protect Hard Disk
.WPK      Keyboard (file name extension) [WordPerfect]
WPM       Words Per Minute
.WPM      Macro (file name extension) [WordPerfect]
WPOS      Workplace Operating System
WPS       Windows Printing System [Microsoft] +
Workplace Shell [OS2]
WPVM      Windows Parallel Virtual Machine
.WQ1      Spreadsheet (file name extension) [BORPQU]
.WQ!      Compressed Spreadsheet (file name extension) [BORPQU]
WRAM      Windows Random Access Memory
WRE 	  Weighted Random Early Detection [Cisco]
.WRI      Write (file name extension)
WRK       Windows Resource Kit [Microsoft]
WS        WordStar + Workstation
WSAPI     Web Site Application Program Interface [O'Reilly]
WSDL	  Web Services Definition/Description Language [IBM/Microsoft]
WSH       Windows Scripting Host [Microsoft]
WSP	  Wireless Session Protocol
WSUI	  Web Services User Interface
WT        Write Through
WTA	  Wireless Telephony Application
WTLS	  Wireless Transport Layer Security
WTM       Wired For Management
WWIS      World Wide Information System [Internet]
WWW       World-Wide Web [Internet]
WYSBYGI   What You See Before You Get It
WYSIWYG   What You See Is What You Get
</pre>
[SIZE=7]X[/SIZE]
<pre>
XA        Extended Architecture + Extended Attribute
XACML	  Extensible Access Control Markup Language
XAPIA     X.400 Application Program Interface Association
X2B       Hexadecimal to Binary [REXX]
.XBM      X-Windows Bitmaps (file name extension) (black and white)
XBRL	  Extensible Business Reporting Language
X2C       Hexadecimal to Character [REXX]
XCHG      Exchange
XCMD      External Command
XCOPY     Extended Copy
X2D       Hexadecimal to Decimal [REXX]
XDF       Extended Density Format [IBM]
XDR       Extended/External Data Representation
XFCN      External Function
XFDL	  Extensible forms Description Language
XGA       Extended Graphics Array [IBM]
XHTML	  Extensible HyperText Markup Language
XID       Exchange Identifier
XIOS      Extended Input/Output System
.XLA      Add-In (file name extension) [Microsoft-Excel]
XLAT      Translate
XLF       Exceptional Fortran [IBM]
XLIFF	  XML Localization Interchange File Format [IBM]
.XLK      Backup (file name extension) [Microsoft-Excel]
XLL       Extensible Link Language
XLM       Excel Macro Language [Microsoft]
.XLT      Template (file name extension) [Microsoft-Excel]
XMIT      Transmit
XML       Extensible Markup Language
XMM       Extended Memory Manager [LIM/AST]
XMS       Extended Memory Specification [LIM/AST]
XNS       Xerox Network System (protocol) [Xerox]
XOFF      Transmitter Off
XON       Transmitter On
XOR       Exclusive OR (Also EOR)
XP	  Extreme Performance [Compaq]
XPCOM	  Cross Platform Component Object Model [Mozilla]
XPE	  XP Embedded (see WIN...XP) [Microsoft]
XPRM      Xerox Print Resources Manager [Xerox]
.XPM	  X-Windows Pixelmaps (file name extension) (color)
XRI	  Extensible Resource Identifier
XRNS	  Extensible Resource Name System
XRT       Extensions for Real-Time
XSL       Extensible Style Language
XSLT	  Extensible Stylesheet Transformation
XSMD      Extended Storage Module Drive (interface)
XSSI      Extended Server Side Includes
XTAL      Crystal
XTCLK     External Transmit Clock
XUL       Extensible User-Interface Language [Netscape]
</pre>
[SIZE=7]Y[/SIZE]
<pre>
YAM       Yet Another Modem [Omen Technology]
YAHOO     Yet Another Hierarchically Officious Oracle [Internet]
Y2K       Year 2000
(Y/N)?    (Asks for a YES or NO decision)
YTD       Year To Date
</pre>
[SIZE=7]Z & #[/SIZE]
<pre>
.z        Packed file (file name extension - using Pack/Unpack
program)..lower case z..[Unix]
.Z        Compressed file (file name extension - using
Compress/Uncompress program)..upper case Z..[Unix]
ZAK       Zero Administration Kit [Microsoft]
ZAW       Zero Administration for Windows [Microsoft]
ZBR       Zone-Bit Recording [IBM]
Z-CAV     Zoned Constant Angular Velocity
ZDL       Zero Delay Lockout
ZDS       Zenith Data Systems
ZIF       Zero-Insertion Force (socket)
ZIP       Zigzag In-Line Package +
Zone Improvement Plan (ZIPcode)
.ZIP      Compressed File (file name extension) [PKWare]
.ZOO      Compressed File (file name extension) [Dhesi]
ZPV       Zoomed Port Video [Toshiba]
ZSL       Zero Slot LAN
@         At + Commercial At
{ }	  Braces
[ ]	  Square Brackets
~         Tilde
(_)	  Underscore
...	  Ellipsis
*         Wildcard character (asterisk)
*.*       Star-Dot-Star (represents
Any file name.Any file name extension)
.$$$      Temporary File (file name extension)
1GL       First Generation Language (machine language)
24/7	  Twenty-Four Hours a Day, Seven Days a Week
286       80286 (microprocessor)
2GL       Second Generation Language (assembly language)
386       80386 (microprocessor)
3COM      3 Com Corporation (The 3 Coms are
Computer, Communications and Compatibility)
3GL       Third Generation Language (programming language)
486       80486 (microprocessor)
4GL       Fourth Generation Language (descriptive language)
6DOF      Six Degrees Of Freedom
</pre>
