Coffee Lake + 3333MHz CL16: avoiding SA & VCCIO tweaks
TheF34RChannel
I've been asking around but I'm afraid my question got lost in the plethora of posts that followed, understandbly. I've got the above combination coming on a Z370 (Apex) board (+ 8700K).
Having watched Tom's CPU review I'm kinda annoyed with myself for openng the packet a day before I watched the video (oops) as I after realised that 3200 CL14 is the sweet spot and you can (theoratically) just enable XMP without messing with voltages.
I was wondering which of the following routes will be neccesary to take for me (in all likelyhood) with the 3333MHz set:
a) Enable XMP and since it's so slightly over 3200 the SA & VCCIO won't need tweaking;
b) Set up the frequency, timings, DRAM voltage manually and thus avoid the board auto increasing the SA & VCCIO (?)
I really do not want to play with the SA & VCCIO voltages, it's not for me.
Whatever the voltage is for your memory is what you should stick with. If it says 1.25, stick with that. I don't see a real point in going past what your kit is rated for. I've never had a kit that did more than advertised even with more volts.
I think there's a misunderstanding; I don't plan on overvolting it. I don't want to play with the SA and VCCIO voltages because my memory is 3333 and am asking if I can avoid that somehow. :)
Id manually set them and work on lowering them no matter what if I were you
I hear you, however that's exactly what I'd like to avoid; I dislike messing with memory voltages so much (past experiences ha ha). But, it seems I have no choice ha ha! Thanks, and I'll manually set all primary timings, voltage and frequency.
Use the XMP profile to get the timings and then it is just a case of lowering the voltages manually.
It can really aide in controlling temps if you take the time and get sysagent and vccio dailed in. Really helped my 7700k but I still delidded anyways cause I wanted 5 GHz nice and cool.
