Cod4 Windowed mode
Pretty sure there's a console command for it.
[font=verdana, arial, helvetica, sans-serif]r_fullscreen 0 [/font]
[font=verdana, arial, helvetica, sans-serif]I think that works, restart once you put it in.[/font]
enable commands
open cmd
type in r_fullscreen 0
then the comand to reset video which i cant remember something like vreset or something
or do it manually i.e. go to cod4 files, players, "player name" , then either cfg or mpcfg file open in worpad and ctr+f fullscreen, and change value from 1 to 0 then just save and it should work
edit your shortcut and stick this on the end. +r_fullscreen "0"
although not always works try that aswell
