Clocking My system
artistic
Asus Striker Extreme nForce 680 (Socket 775) PCI-Express DDR2 Motherboard
Corsair 2GB DDR2 XMS2 Dominator PC2-8888C4 TwinX (2x1GB)
CPU Intel Core 2 Quad 2.66GHZ
BFG GeForce 8800 GTX OC 768MB Silent WaterCooled GDDR3 HDTV/Dual DVI (PCI-Express)
I have the system water cooled
Im looking to clock the system a little and need some help with the mem and any other pointers anyone can help with :-)
Extreme Tweaker Memory Timing
tCL (cas latency) - auto
tRCD - auto
tRAS - auto
command per clock (cmd) - auto
advanced memory setting
tRRD - auto
tRC - auto
tWR - auto
tWTR - auto
tREF - auto
Async Latency - auto
Extreme Tweaker Voltage
Vcore Voltage - auto
Memory Voltage - auto
1.2V HT Voltage - auto
NB Voltage - auto
SB V Voltage - auto
CPU VTT Voltage - auto
DDR2 Controller Ref Voltage - auto
DDR2 Channel A Ref Voltage - auto
DDR2 Channel B Ref Voltage - auto
To start off with:
tCL (cas latency) - 4
tRCD- 4
tRP - 4
tRAS- 12
command per clock (cmd) - 2T
tRRD - auto
tRC- auto
tWR - auto
tWTR - auto
tREF- auto
Vcore Voltage - depends on CPU and level of OC
Memory Voltage - 2.3-2.4v
NB Voltage - one option above middle
SB V Voltage - auto
Seem to be working fine with your settings will run ramtest tonight someone has said you can push it to 5,5,5,18 ?
Also is there much u can do to push the CPU or is it best to run that as normal?
Run two sets of Orthos (copy and paste into two folders) which should stress out your quad
RTHDRIBL will heat the GPU up nice
"Pushing" with memory timings would mean lowering them to reduce latency, i wouldnt expect to be able to push your timings (4-4-4-12) much lower as they are already pretty darn low.
Have a look on Overclock3Ds main site for guides on overclocking your CPU
