Davros1987
Hit me with your knowledge Overlock3rs!
If your temps are holding steady and everything appears to be running in their nominal ranges, is there still need to clean your watercooling loop?
Granted this might go against popular convention but is it going to cause any real issues that you wouldn't pick up on with your temperature readings etc.
I don't use dye in my loop & all visible components seem to be clean as a whistle.
Just putting it out there.
