Circuit Box - HAF XB mod
Full system specs (as of right now, may change)
  • i7-3770k with EK HF Supreme
  • Gigabyte GA-Z68X-UD5 (possibly with EK full cover block - not sure yet)
  • 2x XFX 6870 with EK FC 6870 blocks
  • 16GB Corsair Vengeance DDR3-1600
  • 120GB HyperX 3k SSD (OS)
  • 1TB HDD (maybe larger) (Storage)
  • Enermax Platimax 1200W PSU (cables shortened and sleeved with paracord)
  • Lepa LP70D12R fans
  • Bitspower Multi-Z 250 acrylic res
  • Bitspower fittings and flow meter (building custom system monitoring system)
  • Laing DDC 18W pump w/Bitspower acrylic top
  • Mayhem's Pastel Mint green coolant w/blue dye (to darken it a tad) and UV dye added
  • 2x XSPC RS120 and 1x XSPC RS240 radiators
  • Fan controller - still TBD. I may use the Sentry 2 I already have or go with something different
  • "Monster" green/black paracord
  • 3 windows - top and both sides
  • TONS of laser-cut and laser-etched goodies from White Light Laser - fan grilles, res accent parts, GPU backplates, sponsors' names etched into side panel windows
Alright time to post some progress!
Alright small update for the first one, but there's plenty more to come.
I took out the factory mesh on the top panel and made a window for it.
Next up I started getting some hardware mounted so I could figure out the routing for my tubing. The board shown here is just for mock-up.
Next I drilled mounting holes for the pump mount and mounted the pump.
Then I drilled holes for the reservoir mount. Being that this case is short and fat rather than the typical tall and skinny I decided to mount the res to the back panel.
Here's a shot with the board and GPU's I'll be using. I'll be using my current XFX 6870's paired with their EK blocks. The board shown here I'll be using along with an i7-3770k and the EK block shown here. I still need to strip the block mounting bracket from the last mod and repaint it black for this one. I also plan to remove the MB heatskink setup and paint the blue trim pieces green to match the rest of the mod.
And last up a shot of the green/black paracord I'll be using to sleeve all the cables for the mod.
I've got some Mayhem's pastel mint green coolant mixed up and waiting for the build as well. I think the whole black and green theme will look killer in this.
I'm also debating on adding another 120mm rad in the floor in the 5.25" drive bays for some extra cooling, but we'll see.
This is going to be good!
And welcome to the OC3D forums mate! I hope you'll enjoy your time here :)
Also, why don't you introduce yourself to the forum members in the introductions section (http://forum.overclock3d.net/forumdisplay.php?f=14).
EDIT: Could you also put the Rig's specs in the Original post? I'd love to see the complete specs of this system :)
Does look good...
But a slim 240mm and a slim 120mm for 2 GPUs and a CPU?
Even though the GPUs aren't exactly high end, I still feel temps would be a little high with that little rad space.
I'll introduce myself there and I'll put the specs in :)
Does look good...
I've also got a second 120 rad (see update below) that will be in the system. I ran an i7-960 @4.2GHz, 3 sticks of Kingston H2O ram and a 6870 (and later the second) on a 2x120 and a 1x140 in my last mod with no issues at all, this 3770k runs cooler than the 960 did as well, so I don't think I'll see any issues. Plus I'm limited for space for internal rads unforunately so I need tow ork with the room I have :D
Time for an update :D
The two 6870 waterblocks were starting to get slightly stained, so I took them apart and hit them with some Mother's metal polish with the Dremel and buffing wheel and cleaned them up pretty good.
I also cleaned up the nickel on the CPU waterblock as well as stripped the old paint of the retention bracket and re-painted it black
I also got my care package in from Performance-PCs[/url]! I got a second XSPC 120mm radiator, some Bitspower fittings and some other assorted goodies.
I decided to mount the second 120mm rad on the bottom of the case in the 5.25" drive bay compartment. I'll be using a fan controller but it's short and won't interfere with the fan/rad setup at all.
I also removed almost all of the 3- and 5-way snake rotary fittings to clean up the overall look. It looks much cleaner this way and the Duralene tubing I'll be using is very flexible so I don't need perfectly straight line-of-sight from one barb to the next.
Next up I drilled a hole at the back of the case for the Bitspower panel fitting. This will allow me to connect the reservoir and pump through the back panel of the case.
I had to notch the motherboard tray support just a tad so the panel fitting lock ring would fit properly.
Then I installed the necessary rotary and barb fittings to line everything up.
I also got my i7-3770K in for the build
I used my custom fan template from White Light Laser[/url] to mark the bottom of the case to cut out for the 120mm intake fan for the lower radiator.
Silly me marked the holes for the 120mm fan but marked (and unfortunately cut) the large hole for the 140mm fan. No worries though, I'll make something to clean it up.
Next I made an accent piece for under the pump mount. This not only gives a little look to the pump mount it also raises it 1/8" so the pump to radiator fittings line up better. It's not 100% in this shot, it still needs trimming and cleaning up first, this was just a test fit.
Then I sleeved the pump's wires with the black/green paracord. This was my first time working with paracord and I like it a lot.
And finally I cut a small piece of tubing for the pump intake. The crystal block is a "T" style and the system temp sensor will go into the bottomside opening.
That's it for now!
Thanks :) nice truck you got there - what is it? (my work computer's monitor is very dark so I can't make it out well) I had a T-Maxx back in the day with a .21 conversion chassis and an HPI .24 big block - that thing RIPPED :D
ehrmahgerd... that looks so damn good so far. Haven't really seen any builds in this case here just yet, looking forward to how this one will turn out. HUGE fan of your decision to mount the res where you did... good stuff!
Looks great bro awesome work, I have a question have you tried to put the top panel back on because with the lip the top panel has in the back may look like the res bracket may keep it from going on... Just asking and by no means am I knocking your working.. I cant wait to see the finished product...
Good eye! I took that into account when mounting the res brackets, the top of the bracket is exactly flush against the bottom of the top panel lip and the middle-ish bracket is under the lip's handle bump as well :)
Defiantly going to be something to be proud of! looks amazing already, i cant wait for the result!
Thanks!
