Chipset
IIRC it's 680i.. or a mix of the high end SB and mid end chipset (650i).
Who knows, lmao. Check ASUS' site.
I've just bought the 680 version. Just need memory and graphics to get it running.
Didn't find Asus website much use though. Seems to take ages to load, if at all.
Can someone tell me what the numbers mean anyway (570, 650 etc) with reference to graphics card compatability.
:sleep:
if you have the true 680i (or indeed the 650i+570 hybrid) you can run dual x16 in SLI.
You should be able to run any single PCI-E gfx card or 2 equal nVidias in SLI.
