Here's a 10 minuet mod
Ok so your Building your new Rig and you've got a case the size of a small fridge,
you want CCFL's in it Rather than have 1 Tube per Inverter or you just want to hide them wires out of sight.
Apologies for some of the pics still gettin used to camera
Your New CCFL with its rather short cable
Get an old Faded or broken Tube (one i bent too much) and Cut off where marked
Bare the wire ready for connecting
Mark Either of the Wires with a Permanant pen, mark the same wire on the new one too. This will help identification
Taking the New Tube, cut off the connector. (i am staggering the lengths as i am heatshinking the entire cable)
Remeber join the marked wires
If your only soldering and heatshrinking the joints put heatshrink on now.
All soldered up now You can test it out
Getting the 5mm Heatshrink on was a bit of a struggle (I Used a big sewing needle as a pull-through)
Job's a good 'un
Time taken: 15 minuets(approx)
Cost: £0.00p (Exactly)
My FIRST (hardware) Tutorial Go easy
Job's a good 'un
