I just purchased two HIS HD 5670 video cards and installed the hardware and drivers with no problems. Where I am getting a problem is with the Catalyst Control Center. It will not open. Every time I try to open it, I immediately get a windows error which says Catalyst Control Centre: Host has stopped working. I've tried uninstalling every piece of ATI software on my computer, re-installing, different versions of the software, etc. Nothing fixes this issue. My graphics work just fine, but I cannot get in to change the settings or turn on Crossfire. It is very frustrating and I have tried everything I can think of short of re-installing windows. I'd prefer not to do that. Here is the info from the error message. Can anyone help?
Description:
Stopped working
Problem signature:
Problem Event Name: CLR20r3
Problem Signature 01: ccc.exe
Problem Signature 02: 2.0.0.0
Problem Signature 03: 49ef8e09
Problem Signature 04: mscorlib
Problem Signature 05: 2.0.0.0
Problem Signature 06: 4bf4c227
Problem Signature 07: 20c7
Problem Signature 08: 143
Problem Signature 09: N3CTRYE2KN3C34SGL4ZQYRBFTE4M13NB
OS Version: 6.0.6002.2.2.0.768.2
Locale ID: 1033
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
Here is what I'm running on my machine:
Intel Core 2 Quad Processor
4 GB RAM
2x HIS HD 5670 w/ IceQ
650W PSU
Windows Vista Basic 64-bit
I've tried CCC versions 10.11, 10.10, 10.9, and 10.1. All have the same result.
Here are the details from the event log:
Faulting application CCC.exe, version 2.0.0.0, time stamp 0x49ef8e09, faulting module KERNEL32.dll, version 6.0.6002.18005, time stamp 0x49e041d1, exception code 0xe0434f4d, fault offset 0x00000000000176fd, process id 0x14d8, application start time 0x01cb926d25cc7175.
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2010-12-02T22:06:25.000Z" />
<EventRecordID>23338</EventRecordID>
<Channel>Application</Channel>
<Computer>Galactica-2</Computer>
<Security />
</System>
- <EventData>
<Data>CCC.exe</Data>
<Data>2.0.0.0</Data>
<Data>49ef8e09</Data>
<Data>KERNEL32.dll</Data>
<Data>6.0.6002.18005</Data>
<Data>49e041d1</Data>
<Data>e0434f4d</Data>
<Data>00000000000176fd</Data>
<Data>14d8</Data>
<Data>01cb926d25cc7175</Data>
</EventData>
</Event>
Description:
Stopped working
Problem signature:
Locale ID: 1033
4 GB RAM
650W PSU
- <System>
<Level>2</Level>
<Task>100</Task>
<Security />
</System>
- <EventData>
<Data>14d8</Data>
</EventData>
</Event>
