Case that fits two 360's?
Rich_
Anything out there that fits two 360 rads without cutting or drilling, and preferably under the 250~$ price range?
Or alternatively, what kind of radiators does the switch 810 fit, internally only, without any modifications?
Switch can fit 360/420 in the roof, and a 240/280 in the bottom or front. Each can be 80mm thick with push pull but in the top its push or pull
The switch 810 and phantom 820 fit the same amount of radiators. They are basically the same case with different plastic outsides.
if not into hacking up the case, look to the CaseLabs cases.
yes, expensive, yes can hold whatever you can buy (afford) in radiators.
360/420/480 in the roof, 360/420 in the front intake, natively, no dremel needed.
look into the CaseLabs SM8 for a smallish profile or if you need more ST10..
some get intimidated cutting up a $250 case with non-reversable consequences.
how's the 800D? No fans in front?
----- Or the 900D, any eta on release and msrp?
I do think the NDA is the 28rd feb, so i do think Tinytomlogan is on that case. But you will never now, before it hits the forum and Youtube ;)
