J Jacob.xray New member May 9, 2012 #1 I would like to put LED's on the side panel but don't wont to keep unplugging the cable every time i open it and was wondering if there is anyway around this. Thanks
KING_OF_SAND New member May 9, 2012 #2 You will have to make contact points on the case were if door makes contact with the case the lights turn on. Simple concept, not easy to execute.
